torque arm
Old Mar 28, 2009 | 02:20 PM
82camaroWI's Avatar
torque arm
is the torque arm nessary? i am droping a 400 with a 350 turbo in my car, do i need to have the torque arm or can i go with out it?
Old Mar 28, 2009 | 02:24 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: torque arm
Absolutely necessary.
JamesC
Old Mar 28, 2009 | 02:26 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Re: torque arm
Your rear end is connected by the torque arm to the trans mount for drivetrain stability. If you remove the torque arm the rear end will roll up and be out of alignment. You have to have the torque arm.
Old Mar 28, 2009 | 06:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Well, you don't have to have the torque arm.
But, you do need something to keep the rear axle assembly from twisting.
Old Mar 28, 2009 | 06:36 PM
82camaroWI's Avatar
Re: torque arm
alright, so ill just get a trans out of a camaro then
Old Mar 28, 2009 | 07:25 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
Re: torque arm
b&m and hurst make kits to adapt the torque arm to the th350. i have personal experience with the b&m kit, realatively easy to use. also jegs and a few other companies make crossmember mounted or trans tunnel mount brackets, so the torque arm can be retained. beyond that it boils down to personal preference about transmissions.
Old Mar 28, 2009 | 07:51 PM
82camaroWI's Avatar
Re: torque arm
yah i looked at the b&m kit, if i my buddy gets me a cheap th350 i am going with it
Old Mar 28, 2009 | 07:55 PM
bart91406's Avatar
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
Re: torque arm
I have been asked this question once before, and it makes me wonder, has anyone ever "oh I don't need this, excess weight" and tried to drive without it? That would be interesting to say the least!
Old Mar 28, 2009 | 07:57 PM
82camaroWI's Avatar
Re: torque arm
from what ive heard, with out the torque arm, when you punch it, u will just light em up for days. nothing to give you traction. idk if its true or not
Old Mar 29, 2009 | 12:06 AM
five7kid's Avatar
Without the torque arm, you'll snap your rear u-joint and maybe the shocks at the first application of power. Without the torque arm, the rear springs are enough to send the pinion skyward.
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
