Fuel pump problem on swap
Car: 1987 IROC Z28 1le brakes
Engine: switching to 383
Transmission: installing tko 600
Can I use the external fuel pump that came with the HSR package on my engine swap without pulling the in tank pump out? Or will the in tank pump restrict the fuel to much? It is my understanding that the stock pump is not good enough for a 383 HSR swap.
Transmission: 4L80E/4L80E
The in-tank pump either needs to be running, or it needs to be removed.
If it wouldn't supply enough fuel to the HSR pump, it should be removed.
Re: Fuel pump problem on swap
Thanks.
If I pull it out of the tank how do I run a new pickup for the external pump? Any ideas how this is accomplished? Do I have to fabricate something for to cover the top of the tank or do they make something to fill the hole created by the removal of the pump and has a pickup for an external pump?
There's a sticky in the top section of the Carburetor forum about converting an in-tank electric pick-up for an external pump.
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Could not find it when I searched. thanks again!
