engine swap?
Old Mar 31, 2009 | 11:39 PM
jamesh23's Avatar
engine swap?
so ya there is a huge hole in the block of my 1991 z28 5 spd car, whats the strongest engine i could put in the car that will allow cheap upgrades to it? id also like to put in a new tranny.
dont have much money though, they will be from a junk yard.
think i could possibly get a 327 or 350 and a 4 spd, 5 spd, of 6 spd tranny for 800? with under 100,000 miles maybe?
Old Apr 1, 2009 | 11:13 AM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Re: engine swap?
I would look for an older chevy truck motor if you are trying to find "strong" motors. I don't know exactly what you mean by strong, but the four bolt main is stronger internally than a two bolt. You could most likely find an '80s or even '90s chevy 1500 or 2500 with a decent 327 or 350. You might not get an EFI engine for that cheap though. What you should be on the lookout for is one of the 4 bolt main 350s which came carb'ed in most of the 2500 trucks throughout the 80s. Good luck on the trans, I would keep the one you have unless there is something wrong with the internals. I would expect to pay near 800 for the engine alone if it runs and is indeed a 4 bolt main 350.
Old Apr 1, 2009 | 02:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A 2-bolt main engine is actually stronger internally than a 4-bolt main engine. All the extra two bolts do is help reduce "cap walk".
An '87-up engine makes more sense. The 70's engines were really poor from a quality standpoint, didn't always have things like lifter bores or starter mounting machined correctly, porous castings, casting shifts, etc., etc., etc. Quality improved greatly with the advent of the one-piece rear main seal engines.
Most likely the hole was caused by over-revving stock rods & rod bolts. You "fix" that by replacing the stock rod bolts with ARP bolts. And, not over-revving your engine.
The likelihood of finding a 350 in a junkyard with fewer than 100k miles is getting less and less with each passing day.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
