What do i need exactly from my donor?
Old Apr 3, 2009 | 04:50 AM
LD1985's Avatar
Car: '91 RS, 1994 Honda Accord LX
Engine: 3.1
Transmission: Automatic
I'm trying to replace the 3.1 in my 91 camaro with a v8. I've found a guy in town parting out an 87 Firebird with a 305.
I know I need the engine/ tranny and the front springs. Do I need the driveshaft? Can someone please help me with a list of everything I need to make sure I take from the donor while I'm there? I only get one chance.
The sticky mentions the ecm and wiring harness. Do I need the ecm if I'm going from TBI to Carb'd? My v6 is great except a severe wiring issue won't allow it to run which is why I'm doing the swap so I would really like to avoid as much of my old wiring as I can. I'm pretty sure I can use my radiator, the hoses are on the opposite sides as the radiator in my '89 RS and if I remember correctly it's a little bigger.
Old Apr 3, 2009 | 06:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You don't need the driveshaft.
Assuming you're going to use the '87 accessories (a good idea), you might as well get the part of teh engine harness that goes to the rear driver's side corner of the engine compartment. That will contain the ignition power, alternator wiring, gauge wiring, etc. that you will need.
You can leave the V6 ECM in place. That will help with the fuel pump power (as in, keep it operating). But, that's about the only function that will remain that's controlled by the ECM.
You might want to compare sway bars as well. The V8 piece is often larger than the V6 bar.
rubblerubble
Mar 13, 2016 06:57 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
thunder57
Nov 7, 2015 02:28 PM
LittleFranks
Oct 7, 2015 11:26 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
