Looking for a good EFI engine
Car: Camaro RS
Engine: 305 TBI
Axle/Gears: 3.45
I'm looking for a replacement motor for my 92 Camaro RS 5.0 A4 with a BW 3.45 rear end in it. All the engines I see on websites either will not pass emissions or need to be carburated. I like the factory TPI but for the money I can probably get a better engine. I want aleast 300 - 350 horses. Can guys give me some links to to decent engines. Or suggestions
I like the the Ram Jet 350 but not sure if I could pass emissions in Georgia
Transmission: 4L80E/4L80E
Have you considered an LS1? Emissions-legal 305 net flywheel HP.
Car: Camaro RS
Engine: 305 TBI
Axle/Gears: 3.45
Re: Looking for a good EFI engine
Yes but a LS1 can get pretty pricey if you are not doing the swap yourself. I need something under 5000.00 installed
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
Year one has a good deal on engines. Check with them. Tho you would have to change the cam and put your own TPI on it, for around $3000 its a heck of a deal. Summit has a 330 Hp engine for $2719.95. Again get a more TPI suited cam, your intake and you have realitvly cheap 300+hp engine. Get a Vortech TPI base
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
