305 to 400...header questions?????
Old Apr 12, 2009 | 11:10 AM
IIISLACKERIII's Avatar
Car: 1986 trans am, t-tops
Engine: sbc 400
Transmission: turbo 350
Axle/Gears: idk???
i guess this qustion itsnt about if it can be done or not (as i im putting it in the car today) what i want to know is will headers for a chevy 400 fit into a potiac trans am that had a 305 stock? i think it will work because its a basicly a 3gen camaro, im i right? or is my dad right, and im going to have to spend a alot of money on a custom exaust?
Old Apr 12, 2009 | 11:24 AM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Re: 305 to 400...header questions?????
in my summit mag i came across hooker headers for engine swaps + to accommodate for the car's frame.
Old Apr 12, 2009 | 11:34 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Headers from a trans am and a Camaro are interchangeable, as long as they both have SBC's and are third gens.
Old Apr 13, 2009 | 10:16 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
I did a sbc 400 swap into my 89 Camaro that had a 305 in it originally. Headers will be exactly the same mounting/fitting.
Old Apr 13, 2009 | 12:29 PM
Engine: sbc 400
Axle/Gears: idk???
what radiator did you use? i still have the stock one (its the 305 one) do i need to go any bigger?
the turbo 350 trans doesnt line up with the mounts on my car, is it ok just to make a bracket that moves to mount, or should i move the mount itself to the trans?
anyone have a drive shaft i can buy that will fit this thing? the one i have is to short, or a place i can buy one...
thanks for the help so far..
Old Apr 13, 2009 | 01:11 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
I stuck with the stock rad, used the stock electric fan (always on), water wetter, and a 160 thermostat. got a bit warm, but nothing dangerous.
as for the trans, i had a th350, but apparently got the right length tailshaft, as it was perfect length for the driveshaft. did have to buy a b&m adapter kit to allow me to stick with the stock crossmember and use the torque arm
Old Apr 13, 2009 | 04:55 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
To use your stock driveshaft you will need to get a long tailshaft th350, or use a driveshaft from an '82 f-body.
Edit: Long tailshaft th350's are usually found in trucks.
Old Apr 13, 2009 | 05:36 PM
Engine: sbc 400
Axle/Gears: idk???
ok, thanks
84z96L31vortec
Aug 20, 2017 12:16 AM
dutch930
Sep 11, 2015 06:58 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
