305 tbi to 383 stroker
Engine: 383 stoker in progress
Transmission: Soon to be a TH400
okay after seeing my 5.0 formula sit for almost 2 years due to a heavily smoking engine, i've decided to start buying some parts for a 383 conversion. Since i work at an automotive parts store, i'm able to put whatever i want on "lay-a-way". Ive been looking at 383 rotating assembly kits from eagle specialty products. the part # is b13405e030. the Specs for this can be found here: http://store.summitracing.com/partde...0&autoview=sku
Im just curious if this is a good kit. it says that the kit is externally balanced. it comes with the harmonic balancer and flexplate. would an internally balanced kit be better??
Transmission: 4L80E/4L80E
What year is the block you'll be using? That kit has a 2-piece rear main seal. Internal balance seems to be more expensive in the 2-piece RMS kits, no sure why that is.
Re: 305 tbi to 383 stroker
i'm going to be using a pre 1988 block with the 2 piece seal. i dont have one ready yet but finding one shouldnt be that hard.
no reason in particular. everything in the kit that i saw listed appealed to me and the 2 piece rear main wasn't really a big deal. its not like i'm going to be putting in an old seal into the engine while im putting it together. so i dont think i'll have any problems anytime soon with it leaking.
mhatfield 14
Oct 24, 2015 07:48 AM
