engine swap question no wrong answer
Old Apr 11, 2009 | 07:47 PM
KRACKER JACK's Avatar
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
so im going to an auction to get a car so i can swap every thing in to my 90 v6 camaro so my question is should i get the caprice with the lt1 or the camaro with the ls1 . can i just swap everything or do i have to buy parts for the ls1 swap i know that the lt1 swap is pretty straight forward i was just wondering if the ls1 swap is worth the extra work if there is any. thanks
Old Apr 11, 2009 | 08:01 PM
automods's Avatar
Re: engine swap question no wrong answer
i think the ls swap would be worth the extra effort, if i had the dough, thats what i would be doing.
Old Apr 11, 2009 | 08:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
depends on the year of the ls1, if its an 01 or 02 go for it! ifs its an earlier one, they have issues with the oil pump and rod bolts.
but, the ls1 car would have all the wiring, accessories act that you would need to do an lsx swap, so if its low mileage, and the price is right, its not a bad deal
I would pass on the lt1 in either case IMHO.
Old Apr 11, 2009 | 09:08 PM
Car: CAMARO RS
so as long as i have the entire car, there aren't any extra parts i will need?
Old Apr 11, 2009 | 09:13 PM
Heslekrants's Avatar
Car: 1990 Camaro RS
Engine: 5.7L Vortec TBI
Transmission: Built 700R4 2800 stall
LS1 would be worth the extra work plus built in upgradeability.
Old Apr 11, 2009 | 09:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
you will still need conversion parts, they range from motor mounts, trans mounts, various fasteners, maybe a trans crossmember, ect.
Old Apr 11, 2009 | 10:13 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
be careful with getting a caprice with an lt1.....(which will be an old police car)..because not all are 5.7ltr motors.....some of them are 4.8ltrs....just a tad bid of info for ya...
Old Apr 12, 2009 | 02:23 AM
Car: CAMARO RS
my biggest concern is with the exaust and the mounts are the going to fit or are they easy to make fit
Old Apr 12, 2009 | 10:52 AM
Car: 1990 Camaro RS
If you are not into fabing your own stuff Hawks sells conversions parts. They have headers too but they are $800.
http://www.hawksthirdgenparts.com/ls...sionparts.aspx
82-92 Camaro/Firebird LS1 Conversion Motor Mounts with Transmission Crossmember
Your Price: $195.00
Old Apr 12, 2009 | 05:49 PM
Car: CAMARO RS
so even though i have the entire ls1 camaro i will still need to buy headers to make it fit?
Old Apr 12, 2009 | 07:33 PM
Car: 1990 Camaro RS
I would think the factory exhaust from the LS1 could be made to work.
Old Apr 12, 2009 | 09:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
its an entirely different car, its not going to be a direct swap.
you would probably use the factory LS1 manifolds, and fab something from there. I do not think the y-pipe setup will work.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
