engine swap 3.1 tbi to carb 305
Old May 5, 2009 | 09:10 PM
jomigjr's Avatar
i have a 92 camaro rs found out that cant do much to engine to boost power. can change the cam and have heads ported but i beleave the engine cant hanel the upgrade. so i decided to swap out the old for the new. my 1st question is will my t5 handel the biger engine. 2nd question is what distributor should i use sence im removing the ECM. 3rd question is the motor mounts i should be able to move them forard and not have to make make mods to them i think. and my last question is there a wiring kit to make it easy for me to hook up the conponatns that are left like altanatior and temp gauses and stuff like that
Old May 5, 2009 | 10:16 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: engine swap 3.1 tbi to carb 305
Wouldn't waste my time with swapping a 305 when swapping in a 350 is the same trouble and expense. There are a ton of stickies & tech articles on swaps - do a search.
Old May 5, 2009 | 11:10 PM
Awesome-X's Avatar
Car: 87 Camaro
I agree. But if you do decide to go with a 305 keep in mind that pretty much everything will swap over to a 350 if you decide to get one eventually
Old May 6, 2009 | 12:56 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
jomigjr, welcome aboard thirdgen.org.
No, your V6 T5 will not handle a V8. A V8 T5 can barely handle a V8.
Read the sticky in the top section of this forum for the basics on the V6 to V8 swap.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
