540 into camaro
Old May 6, 2009 | 02:23 PM
87kmaro's Avatar
540 into camaro
i have the engine. It is a crate 540. However i need help. The vehicle is an 87 iroc z28 with the 305.
1. Do i need to tube out the front end? or can i stick with the unmodified body?
2. what motor mounts?
3. what transmission?
4. what rear?
what else should i kno?
thanks.
Old May 6, 2009 | 02:33 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 540 into camaro
you didn't read the sticky, this is what it's there for. You don't need to tube out the front end. You can use the stock body. Your choice of intake manifold will determine if you can keep your stock hood.
Mounts. You can use the 305 mounts, but you should get EnergySuspension's poly inserts. Transmission: Sell yours before you explode it. You can adapt in a TH400. Or a 4L80E. You can get a TKO600. You can get a T56. That's about the extent of what will both fit and hold the torque.
Rear: Again, sell yours before you explode it. You'll need to either get a 12-bolt from moser or Strange, or a Ford 9" from Currie or someplace.
Old May 6, 2009 | 02:44 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 540 into camaro
I'll also add that Strange offers their S-60 rear, which is based on the Dana 60. And if you want a 700R-4 or 200-4R, these can be built up to hold up to 620 ft-lbs. Just how wild is your 540, anyway? You could get TCI's new 6-speed automatic, and be the first to install it. We'd love to see that.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
