383 Swap best heads/cam combo?
Car: 83 Trans Am
Engine: 385
Hi everyone! I've been a luker for a while now, I have a 1983 Trans Am that I absolutely love. I threw a rod in the 350, and was able to pick up a 383 stroker short block that has been balanced and was built for a 9.5:1 compression ratio.
I have been thinking about putting on the Patriot Performance 190cc heads on it, but I have no idea which cam would be the best to match.
Thanks guys!
Thanks guys!
Car: '86 Iroc-z
Engine: 385 stroker, vortecs, demon 750
Transmission: G-Force T-5
Axle/Gears: 9-bolt, 3.27s
Re: 383 Swap best heads/cam combo?
Ask an experienced engine builder, or contact comp cams i think they have expert technicians to help you choose the right cam for your set up.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
carbureted? is the block a 1-piece rear main seal, or 2-piece? Flat-top pistons, or dished? what gear ratio in the rear axle?
Car: 83 Trans Am
Engine: 385
Yes it's carburated, the block is a 1 piece rear main seal. The Keith Black pistons are dished, (D-cup). The gears in the rear end are stock for an '83 Trans Am, I think that'd be 3:23 or something.
Thanks for your help guys!
On Probation
Engine: several
Transmission: none
Axle/Gears: none
One more question. Where in Utah? whether or not you have emissions testing affects how much overlap you can get away with.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If you have to pass an emissions test, I'd say a COMP XE270HR10, if not, I'd say an XE276HR10
