engine swap question
Old May 12, 2009 | 09:26 PM
da_jester's Avatar
Car: 1992 camaro rs
the 305 in my camaro is shot but i have another one i ust rebuilt and i just ordered a new 700r4 to put in my question is when i get old ones out can i put the new ones in together? or even take the old ones out together i mean there both getting replaced and its so much easire to put them together outside the car and thanks in advance.
Old May 13, 2009 | 07:18 AM
nitemare70's Avatar
Car: 83 Z28
Engine: Comp Controled 350 w/ carb
Transmission: 5 Speed
Re: engine swap question
It can be done either together or apart. The big factor in deciding is if U can tilt the pair almost 45 degrees and still get the lift needed to clear nose of auto. I use a creeper under the auto to rest the trans tail on so it does not have to drag or scoot on shop floor. Hope this helps.
Old May 18, 2009 | 03:44 PM
da_jester's Avatar
Car: 1992 camaro rs
yes it does thank you sir im going to try it with them together and hope for the best lol.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
