Oil filter gasket blowing out while priming 406 rebuild
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I had 3 oil filters blow out will slowly priming my new 406 with a drill motor?
Lost like 5 quarts the first time because I didnt know it blow out. I went under the car after that and i could see the filter flexing under the pressure before the oil blow the gasket out again and showered me! This is a new rebuild never even run. Any ideas??????????????????????? and no i dont have the gaskets doubled up or anything like that. using HP4 Fram filters
Car: 1991 Z-28
Engine: 350 L98 al head Stealth Ram
Axle/Gears: 3.42 LS1 brakes
Re: Oil filter gasket blowing out while priming 406 rebuild
I would say the bypass in the pump also . I've had this happen before on a motor that sat dry for a long time .
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Is this a high pressure high volume pump? By pass valve in the oil pump may be stuck. I know it sucks but need to pull the pan. We have a oil pump tester(oil pump dyno) we use at the shop before the pump goes on an engine. I have heard several bad storys on Fram filters but nothing like this.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Even if the bypass was stuck, the galleries and bearings should drain off most of the pressure. A filter should be able to easily handle 100 psi. If the filter itself blew, it would have to be a few hundred psi.
What all was done to the new engine?
I'd also say to get rid of that Fram filter and buy a Wix filter.
Car: 89 Formula 350
thanks guys.. everyone including my engine builder is saying its the oil pump. Guess I'll start pulling the motor tonight...sucks!
Was the oil pump the problem?
BTW, I recommend oil priming with a pressure gauge while on the engine stand. Then tip the engine on it's nose, then it's tail to check for oil leaks.
1992 Trans Am
May 10, 2023 07:19 PM
maroe624
Apr 16, 2017 08:29 AM
ambainb
Apr 25, 2016 09:21 PM
Navy8125
Aug 21, 2015 09:32 AM
