how can i put an olds v8 in my firebird with a v6 5 speed
Old May 29, 2009 | 01:42 PM
cckc41574's Avatar
i have an 87 firebird with the 2.8 v6 and a standard tranny how can i put the 260 v8 out of my 76 ventura in my firebird and use the same tranny out of the firebird and what all would i have to modify on the car to do this or would it be best if it is possible to just use a chevy 350 turbo behind the olds
Old May 29, 2009 | 02:16 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: how can i put an olds v8 in my firebird with a v6 5 speed
An Olds 260?!?! you must be hurting for $$. You can't put your 5 speed behind it, and using the chev trans requires an adapter, but if you can't afford a better engine, you sure can't afford a custom exhaust to make that engine work, nor the changes for the driveshaft and torque arm.
Old May 29, 2009 | 02:30 PM
cckc41574's Avatar
wat if i kept the powerglide on the 260
Old May 29, 2009 | 02:44 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
you still have issues with the exhaust, driveshaft and torque arm. Leave that crappy 260 alone. Let it rust in peace. It's not that hard to find a running Chevy 305 for under $200.
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
PurelyPMD
May 5, 2016 04:57 PM
deracer
Apr 11, 2016 12:04 AM
64goatman
Sep 9, 2015 01:09 PM
