305 tbi to 350 tpi runnin finally but...
Old Jun 6, 2009 | 04:34 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
first the water pump had a leak. thats fixed now. and theres a check engine light on..info on that well for one there is no exhaust on it just hooker headers and the y pipe. so could it be a false reading from the 02 sensors since theres no magnaflow on it right now?
had to cut off the magnaflow to drop the fuel tank for the new fuel pump...
also, what else do i need to look out for? anyone with previous swap to 350tpi's your help would be appreciated
like for ex is the stock radiator fine? will the a/c hook back up?
thanks in advance..
so far she runs!
Old Jun 7, 2009 | 12:02 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Retrieve the trouble code(s). No sense in guessing.
Old Jun 7, 2009 | 03:39 AM
B&WIROC's Avatar
Re: 305 tbi to 350 tpi runnin finally but...
just use the paper clip trick and get the codes and look them up. simple easy way to fix the problems.
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
92purpz28
Aug 11, 2015 02:30 PM
