swapping 85 305tpi for 89305tpi
Old Jun 11, 2009 | 04:48 PM
redpwr's Avatar
Car: 1985 silver Iroc
I have a 85 iroc with 305tpi that the bottom went out. I have a 305 tpi engine complete with harness and computer out of a 89 iroc. what can i do to make the swap the easiest without hacking the wiring. Also the 89 was bolted to a manual trans and i have a 700 auto. Thanks
Old Jun 11, 2009 | 07:40 PM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
Re: swapping 85 305tpi for 89305tpi
k, if your asking this, are you competent to replace an engine? the short blocks are the same. and thats all you need, so swap it over. there should be no need to hack wires.
Old Jun 12, 2009 | 07:51 AM
redpwr's Avatar
So if the harness out of the 89 will attatch at the firewall on the left side, slide the right hand through for the computer, im good to go. use the flex plate off the 85, the park switch is with the original harness so that will be ok. I will also have to have the chip redone for an automatic and deactivate VATS. Just checking, Thanks.
Old Jun 12, 2009 | 12:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
An '85 flexplate won't fit on an '89 crankshaft. You need to buy a flexplate for the '89.
Old Jun 12, 2009 | 12:34 PM
redpwr's Avatar
Yep, your right, i have one out of an '87 somewhere, that should work.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
jbd1969
Aug 17, 2015 07:06 PM
