Decent heads
Old Jun 25, 2009 | 07:18 PM
87_355ci_Camaro's Avatar
Car: 86 Iroc-Z
Engine: 310ci soon to be 355ci
Transmission: built 700r4
Axle/Gears: I think 3.08s
Decent heads
I came across these heads http://www.summitracing.com/parts/CCA-12319/
My question is are these better then 416 heads on a 350ci? Im talking about after machine work and all that...
A friend of mine said his 86 Iroc 305 with a cam and tune will run harder then my setup which is a XE274 cam full kit, RPM intake, hedman headers, holley 650 carb and 3.42 rear. Just tryin to figure out whats best to spend some money on. thanks
Old Jun 25, 2009 | 07:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Decent heads
Those will work fine on a 350 and anything is better than factory heads. You'll spend a lot more rebuilding a set of factory heads than you will buying a set of fully assembled aftermarket heads.
You can spend roughly twice that much on some even better aluminum heads.
Old Jun 25, 2009 | 09:51 PM
Car: 86 Iroc-Z
Re: Decent heads
I can't afford aluminum or else I'd get a set of afr's. 200cc on the intake should support 400hp??? That's the goal I was hoping for with some bowl work and polishing. I also wanted to keep up the compression to around 10:1. If you know of a better head CC like idk they had a few others to get such as 74cc and 185cc intake ports.
Old Jun 28, 2009 | 12:47 AM
Car: 86 Iroc-Z
Re: Decent heads
Alright well I ordered them bare, ill get the valves someother time, the cam is a 274xe with .480in and .490ex its a complete kit with timing chain, valves o rings and locks, springs and retainers.
Is that head too much for that cam?
midge54
Dec 27, 2019 04:14 PM
dutch930
Sep 11, 2015 06:58 AM
509 camaro fan
Sep 6, 2015 10:43 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
