emmisions
Old Jun 29, 2009 | 09:00 PM
thirdgen540's Avatar
Car: camaro iroc-z
Engine: 383
Axle/Gears: 411's
emmisions
hey guy's im thinking of going with march performance pulleys and bracket kit, now if i go this route, this eliminates the smog pump, i have an 86 iroc-z. if i get pulled over, that might be a problem. and advice? thanx.
Old Jun 30, 2009 | 04:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Stick with a system that has all the pulleys you need.
Old Jul 3, 2009 | 02:45 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: emmisions
you can get an underdrive crank pulley for your stock setup, or for the '88-up serpentine setup.
Old Jul 3, 2009 | 07:36 PM
Car: camaro iroc-z
Engine: 383
Axle/Gears: 411's
Re: emmisions
would this be a stock setup, or a aftermarket pulley that will work with the rest of march's bracket kit and so forth.
Old Jul 6, 2009 | 12:53 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: emmisions
the idea is to avoid using the March brackets, and use GM brackets. The March brackets won't let you keep the smog pump, thus they're illegal.
Mac
Carburetors
Oct 29, 2001 12:58 PM
92fire-audio
Oct 17, 2001 12:40 PM
Ravivo
Feb 15, 2001 03:41 PM
