Please help 305 to 350
I recently swapped a worn out 305 for a 350 engine, i have everything hooked up and running with the exception of the power steering. the 350 has double hump heads which i didn't know has no holes in them. apart from drilling these heads , how can i mount the power steering pump, and where can i find the stuff to do this??
thank you in advance for your help.
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
You can't drill and tap the heads. There isn't enough material there, and there isn't a flat pad for the bracket to mount up to.
You can either get heads that have the holes, or get aftermarket brackets and possibly accessory pulleys.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Please help 305 to 350
summitracing.com, jegs.com, any aftermarket place like that. You're looking for March, or Billet Specialties, or Summit brands, among others.
