Motor Mounts
Old Jul 13, 2009 | 02:32 PM
jimcairns's Avatar
Motor Mounts
I have swapped a 2.8 v6 for a Ram Jet 350, but the Hedman Elilte Headers are a tight fit. Does anyone make a low profile motor mount? I am hoping this will give me some more clearance around the AC box.
Old Jul 13, 2009 | 03:00 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Motor Mounts
The Hedmans are a tight fit even with Moroso solid motor mounts, I did that to my third '85 Camaro. It was originally a V6 car before I installed a small-block.
Old Jul 13, 2009 | 03:34 PM
jimcairns's Avatar
Re: Motor Mounts
Did you wind up putting a heat shield on the AC box cover? Did any portion of the cover melt? If so, how did you fix it?
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
