Can Anyone help me.....
Old Jul 14, 2009 | 05:36 PM
PAIMON's Avatar
Car: 1989 Camaro RS Convertible
Engine: Need help identifying
i have a 1989 Camaro RS
i need help indentifying my engine
the mechanic that worked on it told my uncle that he had swaped the with a corvette one and charged him about 3000 i think, that then broke like 3 months later after that he told him that he would swap it with a Z28 one
and charged him like 3000 bucks more
that was like 4 years ago
from what i remember it looks the same as the one it had
i wanna know what kind of engine it is
the numbers i found on the back of the engine said
W3 GM 14102182
can anyone help me tell weather it's the original or a different engine
please...
thanks.
Old Jul 14, 2009 | 05:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
14102182 is the intake manifold casting #. Doesn't tell you much, as it is very likely that the intake manifold moved with every engine change.
You need to look behind the driver side head for a similar casting number. Or, often the last three digits of the casting number are often on the side of the block, seen from under the car. The last three digits are what really matter, but the whole number makes it easier to look up on http://www.mortec.com/castnum.htm .
Old Jul 14, 2009 | 06:00 PM
five7kid's Avatar
Oh, that is a TBI intake, so at least that part did NOT come from a Vette.
Old Jul 14, 2009 | 06:05 PM
Torque22's Avatar
Re: Can Anyone help me.....
Your uncle should have given me the $6000 and I would have built him a engine better than ANY Corvette, or Camaro ever had factory.
Old Jul 14, 2009 | 06:07 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
apparently that casting number dont exist, you should double check it
edit: wow i must be a slow typer or something
Old Jul 16, 2009 | 01:25 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
About 90% of the vehicles that supposedly have a Corvette engine swapped in, don't. In the '70s, that usually meant flat top pistons instead of dished, and in the mid-late '80s, it meant aluminum heads. But most Corvette 350 parts are the same as truck 350 parts, it's cheap and easy to fake a 'vette engine.
Old Jul 17, 2009 | 07:25 PM
PAIMON's Avatar
i looked under the engine
and i could only see that it said 350 on it
Van Nuys born
Feb 25, 2014 06:20 AM
sakattack28
Dec 7, 2012 07:21 AM
Kane82
Dec 31, 2011 01:15 PM
Mrs.Crasher0083
Dec 1, 2011 11:07 AM
