V6 to V8 swap expensive and difficult?
Old Jul 16, 2009 | 02:31 AM
krazynut999's Avatar
ok so i am building a 3rd gen camaro with a 383 v8, i found a good deal on a 2.8L v6 camaro, now i already planned on doing an engine swap with the 383 but i am unsure of how much more expensive and difficult it would be to change from v6 to v8 than a v8 to a v8. i read the sticky article and it told me i would have to change the whole exauhst. but i was planning on upgrading that anyways. also im planning on gettin a performance rebuilt 700r4 tranny. i probably am going to get a donor v8 car like it said. but any input on the diffculty and price of this would be nice thanks.
Old Jul 16, 2009 | 03:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The sticky should give you some idea of the work involved. I'd say the most difficult items are:
- Changing the V6 engine mounts on the crossmember to V8 mounts (the nuts inside the crossmember are a bugger to get to)
- Changing the V6 front springs to V8 (I know many people say they run V6 springs with their V8 just fine, but mine constantly bottomed the suspension until I changed to V8 springs - and the V6 springs had recently been changed by the previous owner) - if you drop the A-arms to change the springs, the engine mount nuts are a breeze to get to
- Fuel system (if the V6 is EFI, plan on dropping the tank and either replacing the in-tank electric pump, or modifying the pick-up for an external or engine mounted pump - see the Carburetor forum for a sticky on modifying the pick-up)
- Wiring
AussiePr0nCar
Mar 6, 2020 04:04 PM
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
theshackle
Aug 22, 2015 06:52 PM
mizz0313
Aug 12, 2015 06:45 AM
