Help engine wont start!
Old Jul 15, 2009 | 01:54 PM
fire_bird07's Avatar
Car: 1986 pontiac firebird
Engine: 305 tbi
Axle/Gears: stock
So i completely ruined my 305 (stock)lol so i swapped it out for another one with h.o heads roller rockers 1/4 lift cam..etc pushin alot more then the s**t one i had but anyway i remvoed the old one and put this one in everything is hooked up but when i go to start it,it wont start it turns over but doesnt want to catch. its almost like there isnt a spark so im completely lost..any ideas?
Old Jul 15, 2009 | 02:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Step 1: Find out if it's getting spark.
Step 2: Find out if it's getting fuel.
Step 3: Find out if it's getting spark at the correct time and fuel in the correct amount.
Old Jul 15, 2009 | 05:46 PM
Engine: 305 tbi
Axle/Gears: stock
Re: Help engine wont start!
its getting a spark i got it to sound like it was gonna start but it didnt and its getting fuel
Old Jul 16, 2009 | 01:46 PM
Engine: 305 tbi
Axle/Gears: stock
i used the distributor from my old engine would that do anything seeing its a different cam?
Old Jul 16, 2009 | 02:59 PM
five7kid's Avatar
No, nothing wrong with using the old distributor. As long as you got it aligned correctly.
Double check your firing order, distributor position, etc.
Old Jul 16, 2009 | 03:59 PM
Engine: 305 tbi
Axle/Gears: stock
ok thank you very much
Old Jul 16, 2009 | 04:34 PM
Engine: 305 tbi
Axle/Gears: stock
ok so i check all my wires,all tight, i checked my distributor wiring,all correct,brought the engine up to the number one cylinder set the distributor in so it is on number one,all vaccum lines are connected and its getting fuel but still nothing at all
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
