what is needed for a V6 to V8 swap
Old Aug 6, 2009 | 11:07 AM
devin142's Avatar
Car: 1991 camaro RS
Transmission: automatic
Axle/Gears: 3.25
i have a 91 comaro with a 3.1L V6. i have a chevy 350 V8 out of a 70's nova and im buying a turbo 350 trans. im very new to building cars like this tho. im 16 and have no clue what this is going to take please help what do i need to get befor i start tering apart my car?
Old Aug 6, 2009 | 12:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Step #1 is to read the V6 to V8 swap sticky in the top section of this forum before you post a new thread about it.
Old Aug 6, 2009 | 04:50 PM
devin142's Avatar
Car: 1991 camaro RS
Axle/Gears: 3.25
Re: what is needed for a V6 to V8 swap
ok i did not see it i will read it thanks
Old Aug 6, 2009 | 05:07 PM
FireChicken2.8's Avatar
Car: 1989 Red T-Top Firebird, 1989 Iroc
Engine: 2.8L 173 C.I., 355
Transmission: Th700r4 Auto, Built TH700R4
Step #2 if you don't find the answers you are looking for, use the search feature. Most questions can be answered with a little searching and reading. This swap has been done a lot, so there is a lot of info on here about it, you just gotta look for it! Good luck!
Old Aug 8, 2009 | 02:39 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
As far as I recall what I had to do was:
(Going from TBI V6 to Carbed V8... besides hacking apart the wiring harness)
- I turned the motor mounts upside down so only 3 of the four bolt holes lined up with the cross member. That gave me just enough clearance to fit the motor but it jammed the bellhousing under the car pretty far.
- Trans mount and plate needs to be changed so the TH350 can bolt up properly.
- Went from electric fuel pump to mechanical (personal preference), you can leave the electric as long as you have a regulator in it.
I also took it a step further and swapped my entire suspension from a Z28.
Where in NJ do you live? If you are local I am willing to give you a hand with it.
$750 L98
Feb 1, 2025 02:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
usafirebird
Sep 29, 2015 11:58 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Gordonr1973
Sep 29, 2015 11:59 AM
