1989 305 tpi-400/406 tpi how?
Old Aug 7, 2009 | 03:23 PM
RedHawkLB9's Avatar
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
Hi, im just curius as to how you can get a 406 Tpi...i i know u can slap vortec heads on there with a vortec tpi intake...but what about the whole serpintine belt drive system..does all that bolt right up?..and is there anything else im overlooking?
Old Aug 8, 2009 | 11:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The block won't change what bolts up except for the location of the dipstick and the type of flexplate/flywheel due to the externally balanced crank & 2-piece rear main seal.
I hope you're not overlooking the fact that the stock factory TPI hardware will absolutely choke off a 400.
Derick15
Sep 17, 2016 05:28 PM
theurge
Aug 21, 2015 12:46 PM
kyleb24
Aug 15, 2015 08:24 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
