305- 383 stroker?
Old Aug 8, 2009 | 02:18 AM
_firebird_'s Avatar
Car: 1988 firebird trans am
Engine: 305 fuel inject. tbi
305- 383 stroker?
I have a 1988 firebird with a 305 H.O. tbi. Id like to turn a 350 that i have into a 383 with about 350-400 hp an put it in my firebird. Any thoughts on this? go bigger, too much, frame troubles, rear, susp.?
Old Aug 8, 2009 | 11:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Every one of our cars should have subframe connectors. If you don't, you really need them with that much power.
Plan at least on beefing up the rear end. You may have 26-spline axles stock, 28-spline are much stronger. Requires a different carrier, good time for an aftermarket posi carrier. Aftermarket gears, welded tubes, aluminum support cover will all help it live behind more power.
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
