Fuel pump Problem
Old Aug 25, 2009 | 05:46 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Fuel pump Problem
What would cause a new tpi pump in a tbi tank to not produce any pressure, the gas barely pours out under prime and crank positions. I dont want to pull the tank again. I had it running but only for about 10 seconds. Now it wont even start and there is only about 1 psi. Did my new pump go bad? Could i have installed it incorrectly?
Old Aug 25, 2009 | 10:07 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Fuel pump Problem
Try the filter - it may be clogged, which could have burnt up the old pump.
Old Aug 26, 2009 | 09:10 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
I had a problem like that where air got trapped in the line I bled the air out by cracking open the line up at motor and pressing in the port till only gas come out on tpi motor also every time I bled air out I would spin motor over to push the air out with gas
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
