88 v-6 to 350? which flywheel?
Car: 85 Camaro Z/28
Transmission: built 700r, B&M shift kit
i am swapping a 350 into my 88 camaro. i bought a s-10 conversion clutch but now i cant find a flywheel that will bolt up to the clutch. can anyone help me with this. i have already tried two flywheels and neither have even come close to bolting up
Transmission: 4L80E/4L80E
What I understood was you use the 3rd gen 153-tooth flywheel and pressure plate, and the S-10 clutch disk.
Car: 85 Camaro Z/28
Re: 88 v-6 to 350? which flywheel?
sorry if i am confusing i wrote that wrong i dont know what i was thinking im just so frustrated at this point. let me start over. basically i have the v6 tranny and i cant seem to find a flywheel to fit the conversion clutch
What I understand is you use a 3rd gen V8 153-tooth flywheel and 3rd gen V8 clutch pressure plate, and an S-10 4.3l V6 clutch disk when mating a V6 T5 transmission to a V8 engine.
That's the "conversion" clutch.
Stangski09
Nov 14, 2015 01:27 PM
Billy Decker
Sep 4, 2015 03:46 PM
