lm7
Old Sep 4, 2009 | 10:58 AM
last_'s Avatar
Car: 91 Camaro RS
Axle/Gears: stock...
lm7
how come i dont see more of y'all goin for the 325 or 5.3 liter version of the lq4? it makes very good power and is just as responsive as the 6 liter but weights less. on top of that is about half as expensive! i have certainly changed my mind from the 6.0L LQ4 too the 5.3L LM7... If I cant sway your opinion maybe this carcraft article can:
http://www.carcraft.com/techarticles...ine/index.html
Happy trails and god bless third gens everywhere!
Old Sep 4, 2009 | 12:53 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: lm7
a lot of the guys have been going with the genIII-genIV blocks recently. I think you'll see more people going for the less powerful version only because they are quite plentiful (meaning very cheap ). Since they are easy to find and cheap to get, there's more money to improve it to similar or better power levels.
I'm still hunting a lsx family block myself. we shall see what the next few days shall bring......
Old Sep 4, 2009 | 02:32 PM
last_'s Avatar
Car: 91 Camaro RS
Re: lm7
Well then, happy hunting friend!
Old Sep 5, 2009 | 05:19 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: lm7
The LM7 doesn't weigh less than the LQ4. Get real. But I did go with the LM7, and I don't regret it.
Old Sep 5, 2009 | 05:21 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: lm7
The LM7 weighs the same as the LQ4. Get real. But I did get the LM7, and I don't regret it.
Old Sep 5, 2009 | 08:26 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: lm7
I was thinking about the LM7 when the LT1 gose south, but around here the 6.0 is $300-400 more. Plus if I have to use f-body brackets,oil pan and so on I belive I'll spent the extra to get the 6.0 the 5.3 is a good choice though.
Old Sep 6, 2009 | 06:40 PM
last_'s Avatar
Car: 91 Camaro RS
Re: lm7
where do you get your data from? cause if you're right i will probly change my mind to a 6 liter.
Old Sep 7, 2009 | 09:05 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: lm7
If anything, the 5.3 is slightly heavier. Forgetting the undesirable pre-'01 versions, all the iron truck blocks use the same water jackets, same exterior, same iron, same everything, except the 6.0 blocks are bored larger, which removes more heavy iron. Yes, the larger aluminum pistons add part of that weight difference back. Both also use aluminum heads, but the 6.0 uses larger valves that are just slightly heavier. Lastly, the 6.0 has slightly heavier counterweights on the crank, to offset those pistons. The end result is the LM7 comes out within 5 pounds of the LQ4. Around here, the 6.0L is only $300 more, but they're in short supply, you have to prepay the entire $800 to get on the waiting list. Screw that. Especially if you want forged pistons, just have the 4.8/5.3 block bored. I've already taken one 5.3 block to 4", no problem.
Old Sep 7, 2009 | 10:21 AM
last_'s Avatar
Car: 91 Camaro RS
Re: lm7
"I've already taken one 5.3 block to 4", no problem." That was gonna be my next question! Very cool, so for my purposes the 5.3 would be better anyway cause im obviously going to bore it. Now, would it be better to play it safe and only take it up to 5.7 total displacement? And I am of the understanding that the '03 or above is the way to go.
Thanks again!
Old Sep 7, 2009 | 12:53 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: lm7
Stopping at 3.903"-3.905", depending on pistons, is the smart move if you're trying for much more than about 500 HP, but going to 4" is proving safe making 492 HP @ 6300 rpm. Also stop at 3.905" if you're going to turbocharge, supercharge, run nitrous, or use it in a high-loasd application such as a work truck. Pre-'01 versions should be avoided. If you decide you want 4", have the cylinder walls sonic-checked first, to be sure they're thick enough. Pre'01 blocks need to be tested before trying for 3.898", and can NOT go to 4".
Linson
Nov 12, 2015 08:09 PM
cRoe4
Aug 8, 2015 02:13 PM
86_irocz-28
Oct 8, 2013 06:57 PM
FIREGRV8
Aug 10, 2010 03:35 PM
last_
Sep 11, 2009 08:37 PM
