question regarding engine codes
Old Sep 4, 2009 | 12:41 PM
jforrest01's Avatar
i have an '84 Z28, i blew the motor that was in it when i got it last week. lol. i have found another engine just not sure of the size. the last 3 digits of the engine code are TPA, i cannot find that code anywhere listed. can someone let me know what size, year and vehicle it was originally in. thanks,
John
Old Sep 4, 2009 | 07:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: question regarding engine codes
Have no idea what TPA is. What your looking for is numbers, on the driver side block at the top - it's really hard to see in the car - they are located directly straight down from where yoour windshield washer motor is. should be like 3970010. www.mortec.com will show you where the numbers are, and what they translate to.
Old Sep 4, 2009 | 08:17 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Casting numbers don't tell you a lot. They're a quick and easy way to see what an engine might be, such as if it's a 305 or a 350. Since the same casting can be used over many years and models, it's hard to say exactly what it is from just a casting number. As an example, the common 010 casting for a 4" bore block was used for many years to make 302, 327 and 350 engines.
Suffix codes are usually hard to read. Since they're stamped in, some letters can easily be mistaken for something else. The letter B or R could look like a P or an F etc. It all depends on how well the letters are stamped into the metal. What are the rest of the numbers stamped in that area. They'll tell a little more information.
TPA
Well T means it's out of a truck. Usually a pickup, van or bus but I also can't find any listing for TPA but that doesn't mean there isn't one.
Old Sep 4, 2009 | 08:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Looks like TPA is one of the newer casting numbers. It's out of a 1992 truck. It's a 350 rated at 210 HP with a TBI. It's an L05 engine.
Old Sep 5, 2009 | 01:37 PM
jforrest01's Avatar
thanks, that makes sense from what i have been told abou it. the number at the back of the block is 10054727 again i cannot find that # either
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
