no start very confusing
Old Sep 8, 2009 | 07:30 PM
KRACKER JACK's Avatar
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
i hope that this makes sense i have a 91 camaro tpi motor with a camaro engine wiring harness the dash in the car is from a 91 firebird that had a tbi motor in it and i bought one of those adapteds that go in between the chip and the computer and had the vats deleted with that adapter but im not sure it it is working because i can only get the engine to turn when i put a jumper wire in the starter enable relay i was hoping somebody would have an idea as to why i am not getting any spark or fuel thanks
Old Sep 13, 2009 | 09:15 PM
Car: CAMARO RS
Re: no start very confusing
I think the fuel pump is shorting in the tank could the dash have any thing to do with the problem
Old Sep 22, 2009 | 11:19 PM
Car: CAMARO RS
bump
Old Sep 23, 2009 | 12:09 AM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
when i swapped my car to tpi i tried to use a firebird harness to a camaro dash,same result as you except i was blowing fuses,get a camaro dash or a firebird harness,i know 1986camaro owner here has my firebird one
good luck
luke
Old Sep 23, 2009 | 10:51 PM
Car: CAMARO RS
well i have power at the coil and power going to the pump and a good ground so i think the fuel pump is bad almost every thing as far as acc work with the fire bird dash go i will compare the dash wires and see what i get so after you switched did your car run?
RazorN8
Jan 7, 2022 11:44 AM
lt500r55
Sep 1, 2021 01:30 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
BurlyChev
Aug 22, 2015 01:52 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
