Anyone using the ZZ4?
Old Oct 17, 2000 | 09:57 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I was curious if anyone else is using the ZZ4 right now. What carb are u useing? Do u have any times? What are ur mods? Things I should expect. I am planning on swapping a ZZ4 in my car and converting to carb with a Speed Demon 750cfm vac, secondary. Also have to get a holley 7psi fuel pump with a Mallory return line FPR. Sound good so far?
Eric Natzke
91 Firebird 305 TBI (ZZ4 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-Accel Cap & Rotor
-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://hometown.aol.com/J007Golden/index2.html
Old Oct 17, 2000 | 01:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A lot of people are using the ZZ4, although I'm not one of them
The carb you're talking about sounds fine. You should be able to use the TBI in-tank fuel pump and just add the regulator like you say. I've heard people talk about a temp sensor fitting size problem (smaller on ZZ4 than stock).
If you're anywhere near sea level, you should be in the 13's if everything else is up to snuff.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Oct 17, 2000 | 01:15 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
SWEEEET Thanks man. Anyone else. Where are some fellow ZZ4 people at? I WILL JOIN U!
Eric Natzke
Old Oct 17, 2000 | 05:00 PM
CamaroMike's Avatar
Check my sig. Toooooooooooooooo MANY mods to list but the carb is a 600 cfm Edelbrock.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Oct 17, 2000 | 05:04 PM
CamaroMike's Avatar
New sig test.
ASE Certified CHEVY DEALER Auto Tech
Old Oct 21, 2000 | 04:09 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Hey man, I'm running a ZZ4, have been for over a year now Best thing I've ever done, apart from get Married that is
I run a 750 dp Holley and the engine runs very strong all the way past redline...
Check out my site in my sig, it'll tell you everything you need to know, don't forget to sign my guestbook
L8r
'86 Iroc ZZ4
Best Run 13.8 @ 100mph
I told you to blow the bloody doors off!
http://www.geocities.com/ukzz4iroc/]...rd/Camaro Site
Old Oct 21, 2000 | 04:15 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Just try that sig again
'86 Iroc ZZ4
[URLhttp://www.geocities.com/ukzz4iroc/]The British Firebird/Camaro Site[/URL]
Old Oct 21, 2000 | 04:19 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Man....
'86 Iroc ZZ4
Old Oct 21, 2000 | 01:53 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
cool site man. Thanks for the info and cool pictures to look at.
Eric Natzke
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Sep 22, 2015 08:42 AM
anesthes
Sep 18, 2015 12:34 PM
Magman
Sep 13, 2015 12:14 AM
italiano67
Aug 31, 2015 06:04 PM
