Double hump heads v. vortech heads
Old Oct 24, 2000 | 09:20 PM
LilJay's Avatar
I didnt exactly know where to post this at, but i am at a delima. my buddy will sell me a set of double hump heads, ported and polished, 2.02/1.60 with studs, and roller rockers for $450. i know these heads are good quality. my problem is, i can get a set of vortech heads for 100 bucks(i am a mechanic)and then by an RPM vortech intake for 180, and have alot less in the heads. my problem is i dont know which will make more power. $450 v. $280 plus tax, is enough to make me think about getting vortech. i was going to use a 274xtreme cam because i have flat top pistons(about 10:1 comp)and the 2.02/1.60 valves, i figure they would flow to 6000rpm with no problem. if i go with vortech heads, i might go with a 268xtreme cam cause its a little smaller, i will have the same compression, but smaller valves. I have seen hot rod, car craft, chevy high performance get 400 hp out of these heads with minor port work, a 268xtreme cam and less compression than i am going to have. sorry this was so long, thanks for any responses.
Wide Open Till You See God.....Then Brake
Old Oct 24, 2000 | 09:43 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
lets start off by calling them vortec heads as they are not a vortech supercharger, pet peave. You will probably want to use the vortecs as they flow better than camel hump heads and also have accesory holes for stuff like power steering. One thing you might want to know is that you cant use exhaust manifolds on these heads, headers are required. I run the 226/230 Xtreme energy grind on a stock converter and I'd say its drivable and has plenty of tire shredding torque right off idle. These are the best cast iron SBC heads ever to come equipped from the factory (thats straight from Car Craft.).
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
Old Oct 24, 2000 | 09:48 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
13.24@104
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
sorry about the double post
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
