305 to 350 problems.....AAAAAAHHHHHHH!!!!!
Old Sep 13, 2009 | 09:28 PM
555's Avatar
555
Car: 90 Z28, 74 Scout II
Engine: healthy 355
Transmission: t-5
Axle/Gears: 4th gen 10 bolt 3.23
I need some help.... just converted my 305 to a 350 and my 700r4 to a t-5.... I've converted the ecm, knock sensor, injectors, and am running an 8746 computer. My camaro runs a TBI unit and after getting rid of a ton of bugs runs really well once I get going. I am curious if anyones had any problems with the idle after motor swaps.... My maro diesels at idle at best, but for the most part just dies when I come to a stop.... any advice? thanx
Jay and R.I.P.
Old Sep 22, 2009 | 06:59 PM
bigjonathan1's Avatar
Car: 85 camero
Engine: mild 350... for now
Transmission: 700 R-4
Axle/Gears: stock 3.08 ten bolt.
Re: 305 to 350 problems.....AAAAAAHHHHHHH!!!!!
the only thing i can think of would be vacume leaks, maybe check around the intake manifold, also the vacume ports at the back of the manifold
Old Sep 22, 2009 | 07:12 PM
bondodude86's Avatar
Car: 1992 Chevy Camaro
Engine: 5.0
also just for ***** and giggles, double check and make sure you are at TDC and airgap the timing through bumping the distributor..sounds retarded but I know alot of people who do work, and get so excited when they are close to being through, that they forget to time it after its been broken in... You have to remember, the New computer had to take time to re-teach itself once it was run for a bit, so therefor your timing could be off a single degree.
Old Sep 22, 2009 | 07:57 PM
555's Avatar
555
Engine: healthy 355
Transmission: t-5
thanx fellers. I ordered a new TBI chip for a 350, I'm hoping that will help. I had some leaks in my tbi adapter plate, all fixed. Now a few more miles and I'll get my timing re-checked. Wish me luck, pavement awaits, haha.
Old Sep 25, 2009 | 03:00 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
I had a throttle body that ended up leaking where the throttle shaft meets the housing. may help to test by spraying some starting fluid around that area (as with any other kind of vacuum leak, you will hear the engine speed pick up)
Old Sep 27, 2009 | 09:29 AM
Fionnla's Avatar
Car: 85 Camaro S/C
Engine: 350 Vortec 330 HP 650 Demon Carb
Axle/Gears: 3.42 Richmond Powertrax
Did you change to a 350 Spark Control Module?
Disconnect the Ecm Timing control wire to distributor'
(Passenger side by firewall.and set timing at 4 degrees advance/
Unplug Ground cable to battery and let set for about 3-4 minutes.
Connect cable and drive for about thirty miles at normal traffic speed.
good luck...
Old Sep 27, 2009 | 03:32 PM
555's Avatar
555
Engine: healthy 355
Transmission: t-5
wish me luck......
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
