Putting a LS1 into 3rd gen?
Old Oct 11, 2000 | 01:25 AM
Firechicken92's Avatar
Has anybody taken a LS1 out of a new car(like a new vette) and put it into a 3rd gen car? I've got a 92 formula w/350. Are the motor mounts the same? The big question is the computer and wiring. I'll probably swap the six speed in with it at the same time. It will take a lot of money and hard work but I think it's worth it. If I keep the engine stock it should get better gas mileage and have more horsepower than the TPI. Thanks for any help.
92 Formula 5.7 T-tops
Flowmaster 80
Other secret mods.
Old Oct 11, 2000 | 08:35 AM
Get Blown ?'s Avatar
If you would put in an LS1 you need to use it's trans. The input shafts are shorter on the trans used for LS1s. Another problem is you need to make a custom motor mounting "base" made as the LS1 does not use SBC mounts. Also IMO the only real advantage you'd have over a SBC would be the fact that the LS1 is an all aluminum block. Probably a good 70lbs lighter in the front-end then. But don't start quoting me here, this isn't my department.
You can learn more info at these links.
LS1 in a 1987 IROC-Z
LS1 in a 1990 IROC-Z
1989 Camaro RS LO3 WCT5 "The Hose Queen" 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
ICQ: 61342629 AOL IM: BlackSunshineZ28
Old Oct 11, 2000 | 09:26 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
The LS1 oil pan is also very different from a conventional SBC pan. Not sure if it would clear the engine crossmember.
Old Oct 12, 2000 | 03:13 AM
Jza's Avatar
Jza
Other advantages: SFI, 1 coil per cylinder, you can juice it with no modifications to the fuel system (the MAF will adjust that extremely), there's still lots of goodies for LS1s, more modern technology, you can get into 11's on just the motor alone (with a cam), it looks cool as hell.
I will definitely do it if the opportunity presents itself again. (I couldn't this last time because I didn't have the $3000 )
Old Oct 12, 2000 | 05:54 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
I may have access to a 99LS1 out of a vette for a very good price and I'm curious just how much these motors are worth used. 12k miles
Was replaced with crate motor, so everything that comes on one is on this one
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
Old Oct 12, 2000 | 06:21 PM
fredo92's Avatar
Car: 92 Camaro RS
Well, you might want to find out why it was replaced with a crate motor, because a friend of mine works for chevy and he has seen about 10 vette's come in with bent valves...apparently at real high rpm's (like missing a shift with your foot on the floor)there is a piston to valve clearance problem.....so find out if that's why that LS1 came out of the car...just a simple warning so you don't get screwed on a **** motor.
'92 RS convertible with 305/700r4, slp headers, 3" high flow cat, 3" flowmaster w/2.5" outlets/hypertech chip, k&n open element, "modified" eibach springs, kyb shocks&struts, and polygraphite bushings.
Old Oct 13, 2000 | 09:42 AM
fredo92 I'm sure you mean bent pushrods. It happens to the guys with T56s who accidentally go from 3rd to 2nd when trying to shift to 4th at WOT. Can you say ouch?
Old Oct 13, 2000 | 06:01 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
quart of oil every 800 miles, guy said it was getting better
Old Oct 13, 2000 | 10:57 PM
[This message has been edited by Get Blown ? (edited October 13, 2000).]
Old Oct 14, 2000 | 11:18 PM
fredo92's Avatar
Car: 92 Camaro RS
Get Blown, yeah, you're right, I did mean to say pushrods, and in fact, yes it is the t56 boys that can't really shift worth a crap that have that happen to them.
Old Oct 29, 2000 | 05:42 PM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
Usually the missed shift on a t56 happens going from 2nd gear to 3rd with the pedal floored, and the shifter gets slammed into 1st. That mechanically over-revs the engine and bends the push rods and worse.
Of course some of it's people that can't shift, however the number and popularity of aftermarket shifters, must mean the OEM shifter isn't all that great in most people eyes.
It's kinda funny, GM makes those trannys skip shift from 1st to 4th to lower emmissions and save gas, when they should have designed skip shift to prevent the fatal shift from 2nd to 1st at WOT. It's like they got it backwards!
Old Oct 29, 2000 | 07:21 PM
Dave91Z28's Avatar
I think you are going to have to make a custom throttle cable bracket because I think that the vettes use throttle that is controlled by the computer, not a cable. If you got an ls1 out of an fbody it would have a throttle bracket. It would be really sweet to see a thirdgen with an ls1. I heard that the ls1 motor burns oil pretty bad when it is breaking in. After it gets over 5000 miles it usually goes away. Also you would need to find a tranny. Because it would be near impossible to put a c5 vette six-speed in your car.
1987 Corvette Z51 4+3 manual transmission silver/gray
My site
Old Oct 30, 2000 | 12:06 AM
GM makes those trannys skip shift from 1st to 4th to lower emmissions and save gas, when they should have designed skip shift to prevent the fatal shift from 2nd to 1st at WOT. It's like they got it backwards![/B]
It's not GM, it's the goverment. ALL 6 speed cars from 94 and up have CAGS. Even the 10th aniv 6 speed Mazda Miata has it.
Old Oct 30, 2000 | 08:47 AM
Brett's Avatar
Wow - whoever misses a shift like that in a vette has to be REALLY inept at shifting!! My shifter is relatively difficult to get into 1st from anywhere so that means they had to be really trying if they hit 1st. The 3 to 4 shifts on these cars is so perfect and smooth that I can't for the life of me figure out how someone could grab 2nd unless they are so excited that they just yank the shifter back to the left - it really is hard to screw up since 3 and 4 are in a straight line. Call it a guess but I'd say 70% of the people that makes those mistakes and bend the pushrods are either joyriding the car or just don't know how to drive stick.
1991 RS LT1
every imaginable bolt-on, ungodly LT1 355, and 12 pounds of intercooled boost on it's way in '01
2000 C5 Coupe
black/black 6-spd, optional polished rims, first run 13.056 @ 109.52 stock
"So what DOES the back of a Mustang look like?"
eightsixseven
Dec 16, 2024 01:50 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
reiderz iroc
Aug 13, 2015 04:57 PM
