emmisions dilema
Old Oct 30, 2000 | 05:51 PM
Smash's Avatar
emmisions dilema
Im planning on doing either a 383 or 350 motor swap into my 85 TA in the spring. I want to run a mini-ram which dumps the egr system, the smog pump is gone already etc... I'll be swapping out the computer with the new Accel Commander DFI and will be running a catalytic. If I swap out the "regular" cam for the mildest cam on the planet( will have to do every 2 years) and really fine tune the computer, should I be able to pass the sniffer test. There is no visual inspection here. I just have to beat that computerized nose. Do I have a chance?
Brian
some more info : I plan on using forged pistons, AFR heads, etc. Im shooting for the 400 hp neigborhood on the "regular cam". Then Im gonna squeeeze it with a 150 shot. This car will be a weekend warrior only.
[This message has been edited by Smash (edited October 30, 2000).]
Old Oct 30, 2000 | 06:51 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Depending on your levels, you should be able to run a fairly decent cam and still meet emission standards based on what others have done. I believe the ZZ9 cam is suppose to be able to meet California's Emission Level, though I am not sure if it is CARB certified.
One thing to consider is getting your extra lift with 1.6 rockers and switching to 1.5s when it comes time for emissions. Somewhere I even read that there are 1.35 roller rockers available for SBC. So that can help bringing you onside if your cam is a bit too wild to pass emissions.
Mac
Carburetors
Oct 29, 2001 12:58 PM
92fire-audio
Oct 17, 2001 12:40 PM
Ravivo
Feb 15, 2001 03:41 PM
