Early model 350 with late model T-5?
Old Oct 31, 2000 | 12:00 AM
92B4C3051LE's Avatar
I found a really good deal on a short block, and want to replace my 305, with this 355, but it is an early 80's block and I know there is some problems with this working. What are the problems, I've always been told it was the flywheel, but I want to know for sure. BTW this is all going in a 1992 Camaro!
1992 Texas DPS B4C 1LE FE2 5.0/5spd:
Intake and Plenum Ported
Fully Ported Corvette Heads
TPIS Tricks ,No Smog Pump, NOS FI Fuel Pump
K&N's Adj. Fuel Pressure Regulator
Alston SFC's, Energy Supension Hyperflex system
MSD 6AL, SLP 1 3/4" SS Headers
3.73's with 275/55/16's out back...blew those now 2.73 one legger
My complete back seat
encompases my RF tunes...
Currie 9" on the way with 3.70 gears
Adam
Old Nov 1, 2000 | 12:10 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Your '92 crank has a one-piece rear main seal, which has a different mounting for the flywheel than the '86-earlier two-piece seal. The older block will not have provisions for factory-type roller lifters. The dip stick should be on the passenger side, so that shouldn't be a problem. You'll want a damper for a 350.
What problems are you expecting, and what are you planning on bolting on to the 355? Your 305 heads would choke the 355. If you keep your TPI, you'd need '87-later heads for the center bolt angles to match your manifold and to use your center-bolt covers. You'll probably want 22lb injectors. You've already ported the intake and plenum, have an adjustable regulator, and your headers are 1-3/4" primaries, that's all good.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Nov 1, 2000 | 07:45 AM
Nevermind, I've got an big cube L98 on the way. Just to let you know, if you would have payed attention to my signature, some of your questions would of been answered. Tahnks for the info anyway.
Adam
midge54
Sep 2, 2015 06:27 PM
greenyone
Aug 29, 2015 11:08 AM
louishenry
Aug 28, 2015 09:41 AM
Cacike
Aug 27, 2015 05:10 PM
Eric-86sc
Aug 24, 2015 09:01 PM
