need help with pulling engine and trans same time
Old Oct 29, 2000 | 05:32 PM
z28wiz's Avatar
need help pulling my engine out with the trans still on its a 700r4 and 305. Everything is disconnected all i need to lossen is the motor mounts. Any help will be appreciated.
91 RS' TBI 305
mods:
dynomax exhaust, lakewood control arms, gutted cat, pioneer deck, tbi spacer, jet stage 2 chip, K&N four inch element and open element, accel cap and rotor, moroso plug wires, msd blaster coil, bosche +4 spark plugs. Alot more mods to come!!
visit my page http://www.geocities.com/motorcity/pit/8410
Old Oct 29, 2000 | 09:09 PM
Hurtin4Hp's Avatar
Car: Transformed 86 Coupe
Engine: 400 sbc
Go ahead and get your radiator and fan out of the way and start lifting, slowly. Once you have the engine off the motor mounts let the jack down that is holding up your transmission.
Old Oct 30, 2000 | 12:29 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
if you can get your hands on one, get an "engine load leveler". it is the thing that you hook the cherry icker to and then the engine hooks up to it. it has a crank or nut at one end that you turn and basically just changes the angle that the engine/tranny hang. it helped me a TON when i did my swap. i did it mostly without anyone's help. i bought one at pep boys and used it and returned it the next week. hehe. worked like a charm.
-brian
1991 Camaro RS
Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, Edelbrock TES Headers, Edelbrock Victor Series Water Pump, Accell Superstock Wires, Cap, and Rotor, MSD Blaster Coil, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
z28boy@twcny.rr.com IM name: Z28 Boy
Old Oct 31, 2000 | 09:49 AM
z28wiz's Avatar
thanks guys!!!
91 RS' TBI 305
mods:
2001 camaro SS LS1, T-tops, 6 speed, Hurst shifter, cags!, power everything
[This message has been edited by z28wiz (edited October 31, 2000).]
Old Nov 1, 2000 | 09:10 AM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
I just yanked my motor/tranny Sunday. I did it will a chain fall mounted to a beam on the ceiling though. With the radiator removed there was tons of room to get it out. Once it was in the air, I jsut held the tranny up and pushed the car back out of the way.
Mark Lock
- 86 IROC-Z - Torn down for 383/SuperRam T56 setup
- -= IROC Online =- - The site dedicated to the IROC-Z
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
timonator
Aug 11, 2015 09:56 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Exxon Limited
Aug 9, 2015 08:13 PM
