Belt drive Q's
Old Nov 17, 2000 | 08:48 PM
GMFB90's Avatar
Belt drive Q's
On a 6 cyl to v8 swap I ran into a slight dillemma. Id like some advice on a setup for the alternator mount. The engine is an 87 that I converted to TPI from carb. The problem is that now the upper alternator bracket willnot bolt up to the manifold since the styling is different. Should I try to custom grind the bracket, or is there an easier alternative?
[This message has been edited by GMFB90 (edited November 17, 2000).]
Old Nov 19, 2000 | 01:48 PM
ede's Avatar
ede
having been in similar situationsas you i've ground brakets and welded metal on then to get additional length. easies thing to do is find a complete engine and rob all the brackets and pulleys.
-=ICON MOTORSPORTS=-
1st & 3rd
1992 Trans Am
May 10, 2023 07:19 PM
mustangdmurder
Aug 21, 2015 07:17 PM
mcquigg
Aug 13, 2015 02:26 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
