swap 305tpi to 350tpi
Old Nov 21, 2000 | 08:48 PM
88transam5.0's Avatar
I got a price quote from sdpc for $1489 for a 350 #12513151. they didn't give me a whole lot of info. like the HP and Torque rating and I requested to see what I would need to replace as far as replace the computer, manifold, injectors, distributor, or will what I have in my 5.0 tpi would work for the 350. thanks
Old Nov 22, 2000 | 10:05 AM
Damon's Avatar
Only problem you are going to have to tackle is upgrading your fuel injectors. The 305 used little 19lb injectors while the 350 got 22lb units. Your 305 chip will even run the whole setup jsut fine- it doesn't even know the bigger injectors and added displacement are there!
I'll bet the HP and torque numbers are right around what an original GM 350 TPI motor was- somewhere around 250 HP and 350 ft/lbs torque.
Old Nov 23, 2000 | 10:29 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Don't assume you need the larger injectors. Fellow here has a tweaked 350 TPI, and runs better times with 19 lb than 24 lb. You may be able to use your 19 lb'ers with an adjustable fuel pressure regulator.
I've heard people on these boards say don't do it, but when you've seen it work...
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.73 unlimited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, TBD heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
jbd1969
Aug 17, 2015 07:06 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
