Computer Question
Old Nov 29, 2000 | 10:53 AM
1989CamaroRs's Avatar
Computer Question
ok im planning on getting a 350 to replace my 305. The 350 will be using a holley 670 cfm tbi(designed for 87-89 gm trucks). Will my factory ecm and wiring harnesses work? what else will i need to change?
Edelbrock TES Headers, High Flow Cat, Edelbrock Catback, SSM Subframe Connectors
Old Nov 29, 2000 | 12:43 PM
rsilver's Avatar
Here are a few ideas that will get you started. your ECM will work but you will probably need a custom chip for the 350.
You will need a new Knock sensor and I believe a few other sensors are different on the 350. There is a ton of stuff written about this so search the archives cause you will be able to get a complete list of all you will need. Some guys have changed the ECM to the Truck ECM for better tuning ability if you do your own proms. I forget the number of the truck ECM but there is a ton of stuff about this on the prom board. I have a couple of posts asking about this so check the responses to them. A lot of it comes down to how modified your 350 will be. If you do a LO5 caprice with few mods, you may ba able to get away with a GM prom out of an 89 caprice which uses the same computer. Good luck and search the archives and you will get most of your questions answered.......bob
91 camaro RS L03 convert,
t-5, ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
