Next question... motor swap?
Old Nov 29, 2000 | 07:50 PM
HPS's Avatar
HPS
How hard is a 350 swap in my car? What will bolt up, and what will I need to buy/modify?
HPS
My Msg Board, with special sections...- http://www.idlechat.net
HPS
91 Teal Camaro RS
305/350 Heads
With a little luck, skill, and help,
she should be a fast *** 305...
Any ideas, e-mail me, or post to me...
"United We Stand, Divided We Fall"
Old Nov 29, 2000 | 08:16 PM
Abe91Z28's Avatar
from some of the info i've colllected, mostly everything off the 305 will work, But, you will need an AFPR so you can run the #19 injectors at a higher psi? Can anyone else answer this.. i'm far from an expert at this, since i too am going to do the same thing I've also heard that 2 bolts from a 305 TPI system won't fit the 350 block, but i'm not sure. I do know that if u put in #22 inj. You will need a 350 computer. Also you need all the sensors for the 350. and as far as heads go, i'd check older posts on this board, because i'm sure there is a question on it.
-Abe
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
happyhapka
Aug 15, 2015 04:42 PM
st.evel07
Aug 13, 2015 06:15 PM
