Swapping a L98 into a 86 camaro
Old Sep 23, 2009 | 08:08 PM
GI Maro's Avatar
Car: 86 Z28 Camaro
Engine: LG4 305
Hello I was wondering if swapping an L98 motor into a 86 camaro that has an LG4 motor is worth it or would it be smarter to go with a carbed 350. What do you need to do to complete the swap? How can you make around 350-425hp from this type of motor? And Does anyone know Of where i could find one for sale?
Thx
Old Sep 24, 2009 | 02:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Making 350-425 HP (gross flywheel, anyway) with the LG4 carb would be a lot easier than trying to get it out of a TPI engine.
http://www.sdparts.com/product/12496...eAssembly.aspx With a Vortec Performer spreadbore intake, power might be slightly off from that, but the LG4 carb, distributor, and ECM would run it just fine.
Old Sep 24, 2009 | 02:11 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Swapping a L98 into a 86 camaro
swapping in this motor will require a bit of wiring fun (whole new harness would be your best bet), but there should be no issue bolting it in. Now for that kind of power levels, you'll need to upgrade a few other things on the vehicle to not get stuck stranded (rear, transmission come to mind).
if you're starting out completely fresh, there are probably better direction to go to get you to those power levels.
Old Sep 24, 2009 | 02:14 PM
GI Maro's Avatar
Car: 86 Z28 Camaro
Engine: LG4 305
The most horsepower that i've read about with a 305 is a build that makes 325, With the L98 it comes with 240hp, isn't a stealth ram intake, headers, cam, kn cold air, going to make more power? I know that the tpi's have a harder time breathing, so the exhaust, and intake going to make a big difference holley claims a 30 to 40 hp gain with the stealth ram intake ???
Old Sep 24, 2009 | 02:17 PM
GI Maro's Avatar
Car: 86 Z28 Camaro
Engine: LG4 305
Tranny is already been rebuilt with shift kit etc..., rear gears aparentley don't have to be to steep wit a tpi to keep them in the torque brand. I have an electric fuel pump right now do i need another one in the tank?
Old Sep 24, 2009 | 03:06 PM
five7kid's Avatar
Note I said "LG4 carb", not the "LG4 305".
Old Sep 24, 2009 | 08:00 PM
GI Maro's Avatar
Car: 86 Z28 Camaro
Engine: LG4 305
LG4 carb ????
Old Sep 24, 2009 | 09:06 PM
five7kid's Avatar
Get a 350 longblock (you asked where you could find one for sale, I linked an example). Put the LG4 carb, distributor, etc., on it.
I'm trying to say you can get more power out of that system, and for less money, than you ever could out of TPI. To say nothing of it being a lot less hassle than converting to TPI.
Old Sep 25, 2009 | 04:22 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I did the LG4 to L98 Long block swap using the factory carb and distributor (auto trans) back in 1993 and can give you some advice.
What I did - swap out the long block and put all the LG4 stuff back on, supplementing with a performer EGR intake and headers. About 290hp in tuned form without any other changes. Since mine was an 84 with the non roller, I did have to change the distributor gear to a hardened one, other than that, everything else was cosmetic/power adding. Keep in mind that it was a Corvette L98 with aluminum heads that necessitated an oil pan change to a Camaro/Firebird one. Since I painted the pan black, the motor is 100% stealth. The stock trans lasted all of 2 days, even with a big cooler. L98 needs an electric fuel pump (in tank/right outside) as it came EFI from the factory.
Good luck!
1984HO
Mar 19, 2021 11:59 AM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
reiderz iroc
Aug 13, 2015 04:57 PM
matthew911
Aug 12, 2015 09:38 AM
