400 TPI and T-56 in 87 IROC
ok maybe someone has done this before and can help me, i have an 87 iroc with a 305 tpi and a borg warner t-5 , i would like to drop in a 400 small block i have, and use the tpi setup, also would like to drop in a t-56 6 speed while im at it, what do i need to change? what will i be abe to use? any info will be greatly appreciated, thanks.
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
c`mon guys somebodys gotta know something about this, one of my main questions is what starter and flywheel do i use?
look throught the tech articles...i think there is one...or post in the engine board...i remember someone had a detailed account of that t56 swap. for the 400 starter look into the archives a little...there was a guy who gave part numbers. thread started by Black Beauty
You will need part number 700173 from Centerforce for the externally balanced 400. As for starters, you need the small nose chevrolet starter.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Iroc8t8
Aug 26, 2015 08:14 AM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
