350 or 400, from a 3.1
Old Dec 9, 2000 | 10:12 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
What is the easiest, quickest, most inexpensive swap?
Crate 350, 383, or 400?
How can the t-5 be made to handle the torque, and how long could I run the t-5 with it.
As far as the computer and FI system, which engine will be easier to outfit.
Thanks.
http://kiztope.50megs.com
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!!
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14(?))
"No one knows until they learn" Leon Calrinsky (99)
Old Dec 9, 2000 | 10:37 PM
Dan87IROC-Z's Avatar
The 350 is the cheapest and easiest to do for sure. I think there is a kit you can buy to make a T-5 stronger, but I have no idea who makes it or what it costs.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
Old Dec 11, 2000 | 11:34 AM
MILT's Avatar
Externally, all those blocks are the same. Thus they have (bar minor differences) the same holes for mounting heads, manifolds, accessories, etc. A 350 will be the cheapest--they're everywhere. You can use the stock TPI equipment on any of those blocks (w/ pre-88 TPI base); but 350 will probably be cheaper because you'd want to upgrade to higher performance parts in order to get the most TQ 'n HP from the 383 or 400.
Also, it probably wouldn't be worth upgrading the T-5. It would probably cost as much as installing a T56
MILT
[This message has been edited by MILT (edited December 11, 2000).]
Old Dec 11, 2000 | 11:52 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
350 eh?
Thats what I figured...
What do you mean about the pre-88 TPI base.
What are the differences in pre-88 and post?
Ok, 350 blocks...
L98 the newest(highest performing..) one? (ls-1 and lt-1 aren't 350's...)
Thanks so far,
Daniel
Old Dec 11, 2000 | 10:35 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
the LT1 and LS1s are a whole new ball game....if your gonna bring them into the picture then the 350 is not easy LOL...a l98 is easy...the others(lt1 ls1) are a lot harder to swap...and more $$$. i beleive the TPI setup changed from (maf to speed density) or the other way around.
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 5/8 shorties, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo on the way)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
Old Dec 11, 2000 | 11:14 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Believe me, The lt-1 and Ls-1 are not in the picture!
Why is this true? Why wouldnt 88+ work?
You say that its Speed Density vs MAF. Was TPI changed in these years? Or is it just sensors....(& computer stuff)
BTW What year was the L98 first introduced into the camaro line?
Old Dec 12, 2000 | 12:41 PM
Glen's Avatar
Engine: chevy 383
Transmission: tci streetfighter auto
Axle/Gears: 3.70 moser 9"
1987 was the first year the L98 was used. That year a roller cam was introduced and the two center bolt holes of the 6 intake manifold holes on each side were changed to a different angle. TPI setups must be matched to the correct heads to do it correctly. Guys have drilled out the holes to make things mate up but I personnaly don't like doing things that way. In 1986 the blocks were one piece rear main seals but the cam was a much milder non-roller hydraulic. I believe it was 1990 and 91 when Speed density systems were put on our cars. The VATS (vehicle anti-theft systems) were introduced as well. Tricky huh? Try to get the hyd. roller vintage of late model block but stick with the L98. Your swap will be easier but not without a lot of conversion work on the harness etc. Good luck. I'm right in the middle of a conversion of my 85 sport coupe now.
'85 Sport Coupe V6 T5(bought new)Putting in 88 350 TPI/AOD and a bunch of 88 IROC and aftermarket performance parts now.
86 IROC 305 TPI AOD
(selling after Sport Coupe rebuild is done)
Old Dec 12, 2000 | 06:22 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
I understand about not liking to do things that way... I want to get things that are meant for each other....
Aftermarket heads for the L98.. They are year specific? If I ordered heads, it wouldnt just be for any L98.. to have the tpi base mount up correctly, the heads would have to be matched to the correct year...
What are the differences (if any) between the TPI setups besides the bolt pattern?
So 90-92 L98's were a hydraulic roller cam setup? One piece main seal? Is this correct?
Just curious, how much HP were the stock Z's produced with?
Thanks so far!
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
