350, Roller vs Non Roller....
Old Dec 11, 2000 | 02:16 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
So what are the advantages vs disadvantages of each block setup? What about availability of each?
I have been told that the roller stuff creates less friction, and therefore increases drivetrain longevity, but is there anything else it does or doesnt do for that matter?
Thanks,
Daniel
http://kiztope.50megs.com
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!!
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14(?))
"No one knows until they learn" Leon Calrinsky (99)
Old Dec 11, 2000 | 08:19 PM
ede's Avatar
ede
roller cams can run more aggresive cam profiles. you'd also get a one piece main seal if you have a roller block.
ICON Motorsports
1st & 3rd
Old Dec 11, 2000 | 08:36 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
What about as far as a mild (daily driver) cam? Also One piece vs two peice main seal. What are the ad/dis advantages?
Old Dec 12, 2000 | 03:12 AM
Novaguy76's Avatar
As far as a roller Vs. a flat tappet goes it is like the differance between puching a car that is sitting on the frame and pushing a car that has wheels on it. A flat tappet cam has alot of drag with the cam moving on the bottom of the lifters where the roller cam does not. This is where you lose the friction and gain HP. If you take a flat tappet hydrolic cam and a hydrolic roller cam that are the same size the roller cam will make much more power. You would have to go up 2 cam sizes to get the same type gains as you would with the smaller roller cam. Now, as far as a 1 peice rear main seal Vs. a 2 peice rear main seal the big differance is the whole reason they started makeing them that way in the first place.... They don't leak like the older 2 peice rear main seal blocks do.
Old Dec 12, 2000 | 05:55 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
L98 a roller block?
When was the roller block first produced?
Old Dec 13, 2000 | 12:36 PM
Glen's Avatar
Engine: chevy 383
Transmission: tci streetfighter auto
Axle/Gears: 3.70 moser 9"
Yes, the L98 is a roller block and they first placed them into Camaros in 1987. They may have put them into Vettes in 1986 (they are always 1 year ahead of us poor folks cars)
'85 Sport Coupe V6 T5(bought new)Putting in 88 350 TPI/AOD and a bunch of 88 IROC and aftermarket performance parts now.
86 IROC 305 TPI AOD
(selling after Sport Coupe rebuild is done)
Old Dec 13, 2000 | 01:05 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Are there any roller block 400's?
Old Dec 13, 2000 | 05:45 PM
ede's Avatar
ede
no roller 400 blocks but you can put an aftermarket roller cam in any engine.
ICON Motorsports
1st & 3rd
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Eric-86sc
Aug 24, 2015 09:01 PM
