will 454 fit?
Old Dec 11, 2000 | 10:25 AM
soltan's Avatar
will 454 fit?
i was wondering if a 454 taken off a firstgen would fit into a thirgen without complicated modifications?
If yes, then I'd probably have to get another hood too, right?
If not, then what is the largest block that would fit? Except for the stroker of course.
More information on this subject would be greatly appreciated.
Old Dec 11, 2000 | 11:55 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Define complicated.
The info you are looking for is on my page.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
www.koolmeister.com
Old Dec 11, 2000 | 11:59 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
A stroked block is no bigger than any other... the insides are the only thing that's changed (if this is what you are talking about ...383, 427)
There are a few guys on the board with big blocks under their hood. I believe that there is some framework involved, as well as special mounts, besides the fact that they are heavy as heck....
http://kiztope.50megs.com
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!!
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14(?))
"No one knows until they learn" Leon Calrinsky (99)
Old Dec 12, 2000 | 03:23 AM
Novaguy76's Avatar
It is true that the big blocks are much heavier (175 pounds to be exact) but you don't put a big block in your car if you are going auto crossing...lol. If you are putting a big block in your car it is because you want to do something differant (gain extra coolness points for having a big block cruser) or you want to go real fast. I know the second comment can spark a discussion a mile long so before allyou small block guys go nuts here let me say that I know anything can be fast... I have seen VW bugs with 4 bangers beat big block Camaro's...BFD!!!! The point is you have to do alot more to a smaller motor to get it to run like a bigger motor. The only substitute for cubic inches is cubic dollars!!!!! Period! End of conversation!
Old Dec 13, 2000 | 08:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
When I'm done installing mine I expect the car to weigh no more than 100 pounds more if not less than what the race weight was with the small block.
You don't install a big block for HP. A small block can make as much HP as a streetable big block. Of course it's a lot easier to make that HP with a big block. The real reason for a big block is torque and driving stoplight to stoplight is where you'll really notice that torque.
A typical engine should be able to make 1 HP for every cubic inch. A small block 350 can easily make 350 HP and at 500 HP it gets expensive and unstreetable. Now a 454 can easily make 454 HP and when you do the same type of performance modifications for more power like the 500HP 350, the big block now jumps to 600+HP.
I drive a big block every day. I don't think I could go back to driving a small block.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Dec 14, 2000 | 12:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
When I went from stock 350 w/headers and TH350 in the '57 to 396 w/headers and TH400, I gained 100 pounds (well, the car gained weight, not me). Measures taken were: intake went from cast iron to aluminum, radiator from stock brass to aluminum, and removal of some unable-to-use frame brackets & mounts. Also moved the battery to the trunk to help weight distribution, and added a front sway bar (big difference in daily driving with just that). Although both engine/trannies were fairly mild, my 1/4 mile times went down by a full second (TH400 has a higher stall convertor, but is slipping in 3rd). Oh, yeah, had 3.36 gears with the 350, 3.08's with the 396 as well as taller rear tires.
Until I started driving the Camaro last fall, I drove the '57 to work every day, and even took it on a 900-mile round trip to a high school reunion. On my way home from the track, I've had people pull up beside me and say, "I can't believe how fast you get that thing to go!" And that's just with a baby Rat. Sure, that trailer-queen Nomad is 1.5 seconds faster with a 383, and gets a lot more attention, but my investment is definitely much smaller.
The Camaro will remain a smallblock at least for several more years because of one word: Emissions. You can be sure, though, that thoughts have run through my mind like "Ram Jet 502 in the '57, 396 in the Camaro..."
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.73 unlimited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, TBD heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
New2Chevy
Sep 28, 2015 12:35 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
