Motor mounts
Old Sep 28, 2009 | 03:11 PM
BTLD_LS1's Avatar
Car: 1998 Z28
Engine: LS1 347
Axle/Gears: 3.23 currently
Motor mounts
Its been a while since I worked on any third gen cars, so forgive me if this is an ignorant question...
I am dealing with a 4 bolt main motor out of a 70/80's pickup that was then swapped into a nova. The question is, are the mounts on the block the same, or are they different?
I replaced the mounts on the k-member with new ones and when installing the short block I can only get on bolt hole to line up.
Any suggestions welcome!
Old Sep 28, 2009 | 04:52 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Motor mounts
make sure the mounts are facing the right direction, and on the right side of the car. I know they look the same, but they are different for each side, and have to face the right direction.
Old Sep 29, 2009 | 07:48 AM
BTLD_LS1's Avatar
Car: 1998 Z28
Engine: LS1 347
Re: Motor mounts
Are you talking about the mounts on the k-member itself? I purchased them from AutoZone, part number 2292, says fits either side. Are u referring to the fact that there should be a top and bottom to each mount on the k-member? Is there a way to determine which side should be up? Those things are a B*TCH to get on the k-member......
The mounts on the block itself are the same for all the late 70's early 80's cars/trucks?
Old Sep 29, 2009 | 08:00 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Motor mounts
The mounts on the k-member are the same (both sides are the same exact part number). The motor side should be the same from f-body to truck, but it wouldn't hurt to double check. Make sure not to tighten down the one side you've already got in place, leave yourself some "wiggle room" by allowing the bolt to rotate if necessary. The aftermarket stuff sometimes can be a little out-of-spec, so you may need to play with a pry bar to get them both lined up. Remember, those rubber (or poly) inserts are not really held down by anything and can shift around a bit inside the mount housing.
Old Sep 29, 2009 | 08:07 AM
BTLD_LS1's Avatar
Car: 1998 Z28
Engine: LS1 347
Re: Motor mounts
Ill give it a try tonight and see what I can figure out as ill have an extra set of hands. Right now the side that is not lined up sits about 1" too high, not even close to where it needs to be....
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
