who knows how to make speedo work after engine swap?
Old Nov 18, 2000 | 02:54 PM
Pimp Daddy Welfare's Avatar
After I ripped the CPU out of my 92 bird and swapped in a 350, the speedo hasn't worked. Are there any ways to make it work or do I just have to get a new gauge?
Old Nov 19, 2000 | 02:46 PM
Baz89RS's Avatar
I'm not familiar with the 92's but my 89' has it's speedo work from the trans, so when I ripped my computer out it didn't have any affect on the speedo. I know the 92's have the electronic 700R4 that has the ECM shift the trans, so that may be difference....
Old Nov 19, 2000 | 03:12 PM
SeanSullivan's Avatar
Removed my ECM, speedo still works fine. You must've pulled the entire harness out as well. You should be able to get a wiring diagram to wire it back up. I believe it's electronic.
Old Nov 19, 2000 | 08:52 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
1992s do not have an electronic transmission. However, 1992s do have VSS which requires an ECM to receive the electronic signal and sends it to the speedo. Your options are either to hook up the ECM for the VSS or convert to a manual speedo. I would suspect your tach doesn't work either.
Old Nov 21, 2000 | 10:55 AM
No, my Tach still works. Some of my other gauges don't work either, like the fuel, and the think that the temp gauge is off. what a pain in the *** . I will probably end up getting all new gauges.
Old Dec 1, 2000 | 07:58 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
all of the birds have electro speedo's from 85-up the yellow box on the computer bracket is what controlls your speedo
Old Dec 20, 2000 | 02:00 PM
Derek91RS's Avatar
My 91rs has a 79 359 and no computer the spedo has it's own computer and it should work fine unless you pulled the wires out completly it should be two wires i think mine were purple and yello but if you get it hooked up right it should work.
Old Dec 20, 2000 | 05:39 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Check this out.... http://www.angelfire.com/mt/psh/speedo.htm
It should tell you all you need to know.
Pete
Pete's Place
HiOutput Virtual Racing Team
Jorlain
Aug 24, 2022 05:11 PM
theshackle
Mar 5, 2017 06:37 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
beachrodder
Aug 7, 2015 04:27 PM
