454 BigBlock in 92 FIrebird
I am just needing a simple yes/no answer. Will a 454 BB fit w/o any clearance problems other than maybe needing a cowl hood or something into a 92 Firebird. I heard the only thing I may have to worry about would be strut towers, but I want to know if it'll fit and clear these. Someone out there has to know
92 Bird 3.1L Auto
Best $750 I ever spent....
DRIVE IT LIKE YOU STOLE IT!
Kills:
93 Mustang LX (Before Mods)
AIM name OVRCLCK350
92 Bird 3.1L Auto
Kills:
AIM name OVRCLCK350
It will bolt right in with no problems... what you will have to worry about is the exhaust. Other than that it will clear with no problems.
82 Z28 with 350.motor has .030 forged flat top pistions other wise stock bottom end, Summit 214/224 cam with 1.6 Harland Sharp roller rockers, stock 882 heads for now (will be getting a set of the 23 degree Trick Flows this summer), Performer RPM intake, Holley 750 Vacuum secondary, Th350 with 2200 converter, stock 3.23 geared rearend for now (getting 9" later on), Headman shorty headers, custom 2.5" into 3.5" Y pipe into M.A.C. offroad pipe and M.A.C. cat back system. So far car has only been to the track twice and is having sever traction problems but is running 60'-2.34 1/8 mile-9.2 @ 79 MPH.
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Since you only want a yes or no answer, then the answer is no. The biggest fit issue is with the headers, but there is more to it than that. The info is on my page about the swap.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
www.koolmeister.com
Miles
88 427 Camaro
www.koolmeister.com
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
The 454 will fit but I wouldn't recommend it.
It would be much better to stick with a small block. You can get plenty of power with a small block. The extra weight of the big block will really have a negative effect on the handling and braking of your car.
